Forums >> General Discussion >> Revit Project Management >> stair stringers
Wed, Jun 25, 2008 at 7:06:59 PM | stair stringers
jstrauss
Does anyone know a way to have Revit contivue the stringer below the bottom level? It always uts the bottomm of the stringer off at the bottom level even if you uncheck the "start with riser" box. I am trying to model a stair tower, floor to floor heights vary so multistorey is of no use, with the steel stringers appearing to attach to the edge of the floor slab.
The stringers are model correctly at the landings, but not at the floors.
thanks, Jonathan
Fri, Jun 27, 2008 at 3:12:38 PM | stair stringers
lunchtrayrider
3.5 Stars: 7 Votes
go into your stair properties and use the feature "extend below base" use a negative number
I like scooters. and motorcycles.
Lineweight Tool Does Not Function For Stair Stringers....
Mon, Oct 24, 2016 at 4:23:49 PM
steel stair stringers under treads
Mon, Jun 27, 2005 at 8:18:26 AM
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Stair Stringers
Thu, Aug 15, 2013 at 11:32:01 AM
Extend Stair Stringers
Thu, Apr 4, 2019 at 5:54:07 AM
Page generation time: 3.2035
