21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> breakline
10 Posts No Rating |
I am using Revit 2008 and am having trouble using the breakline family. It isn't masking objects within views. Is there a different version of this or something I can do to alleviate this problem. Thank you in advance...
give this a try.
I believe your visibility graphics needs to be set to hidden...
2 Posts No Rating |
when will we have a breakline that scales to the view? I tried to create as a symbol, but shape handles won't work and masking covers levels / grids.
2 Posts No Rating |
45 Posts No Rating |
I think you could make it by creating a parametric annotation familly, with a masking region. then you can set the dimensions that will be view-specific. M.
The out of the box breakline is fully parametric. Just grab the handles and adjust it. Width - masking region - break 'z' all adjust. If you add an element afterwards, you may have to reset which item is on-top (draw-order).
very minor problem with annotation RAC2009 |
Thu, Jan 8, 2009 at 4:44:21 PM
Changing section callouts and breakline symbols (lineweights, types) |
Fri, Dec 28, 2012 at 8:37:44 AM
duplicate detail families |
Mon, Oct 22, 2012 at 8:14:03 AM
Civil 3d surface to revit topo surface |
Tue, Nov 2, 2010 at 2:37:59 PM
Break line in elevation |
Fri, Nov 21, 2008 at 1:01:49 PM
