Forums >> Community >> Newbies >> Outside a Crop View
Wed, Jun 25, 2008 at 1:55:58 PM | Outside a Crop View
notagain
notagain Avatar
4 Stars: 1 Votes
Is there anyway to drawing a line outside a crop view border of detail view.  There has to be a way
I really want this to work...some good things some bad
Wed, Jun 25, 2008 at 2:15:44 PM | Outside a Crop View
lunchtrayrider
3.5 Stars: 7 Votes
what are you trying to achieve?
I like scooters. and motorcycles.
Tue, Jun 9, 2009 at 1:42:15 PM | Outside a Crop View
elduderino1234
I am trying to do the same thing. What I am currently working on are enlarged floor plans. I have the crop region set around the walls but I need to show unit entry tolerances (per code) outside of the current crop region. Is there any way to achieve this without messing with the crop region? TIA
Tue, Jun 9, 2009 at 2:22:43 PM | Outside a Crop View
Use a masking region with a hole in it ... the inside line of the mask is an invisible line where your crop region would normally be.
Tue, Jun 9, 2009 at 2:46:39 PM | Outside a Crop View
elduderino1234
thanks double dub hub, you always come through for me
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:20 PM
Cannot crop drawings in sheet view
Tue, Mar 17, 2015 at 11:05:51 AM
Annotation Crop boundary is not visible
Mon, Sep 24, 2012 at 3:16:13 PM
Viewport is bigger than crop view
Tue, Nov 27, 2012 at 11:27:51 AM
view extents outside crop region
Wed, Jan 5, 2011 at 12:13:56 PM
Page generation time: 3.8571
