Forums >> Revit Building >> Technical Support >> Design Options with Demolition.
Wed, Jun 25, 2008 at 12:53:25 PM | Design Options with Demolition.
mflure
Greetings all,
I'm new to design options and I was wondering if I'm overlooking something.  I'm trying to set up a Tenant Improvement Plan with two options.  Each option has different walls that are demolished or partly demolished and it seems Revit will not allow me to demolish existing walls within the option?  Am I missing something here??  Or is it better to do this with two separate files?
 Thanks,
 Mike
Wed, Jun 25, 2008 at 9:05:40 PM | Design Options with Demolition.
mtyp
You should be able to do this in the project.  We have 3 phases in our firm, Existing then Demo then New Construction.  Try this step by step see if you can get it to work.
Create two or more design Options
Select the existing walls and other objects in the existing phase that will be edited.  Using the green plus icon "Add to Design Option Set" and add your existing walls to all of the options.
Go to the Demo phase and activate the first design option.  Demo and make the changes that you think you need.
Finally go to the New Construction Phase and draw in the alterations.
Rinse and repeat in another Design Set.
Now you should be able to have one existing that looks the same in each option and a different demo and new construction for each.
Good Luck!
Fri, Jun 27, 2008 at 2:40:17 PM | Design Options with Demolition.
mflure
Thanks Mtyp..  I'm actually now on vacation so I'll try it when I return to the grind here in a couple of weeks..
 Mike
Mon, Oct 21, 2013 at 10:46:03 AM | mtyp
hifrank001
Quoting mtyp from 2008-06-25 21:05:40
"Create two or more design Options
Select the existing walls and other objects in the existing phase that will be edited.  "
hi, I have spent a bit time studying design options. Here is one of my observation/comment which I would like you to confirm:
as long as a object (wall, door, floor...) is affected no matter by one option or more, it should be "Add to set". Is this correct?
Mon, Oct 21, 2013 at 11:07:43 AM | Design Options with Demolition.
Only objects that are new, demolished or that host objects new or demolished need to be in an option.  Affected is a bad term because wall joins could be considered affected.   Option set walls will alter base walls at join conditions.
Design options issues
Thu, Mar 2, 2006 at 10:35:31 AM
Design Options
Wed, Dec 24, 2003 at 10:33:51 AM
Titleblocks & Design Options
Mon, Dec 8, 2008 at 2:06:33 PM
design options tied to other objects (version 2008)
Tue, Apr 1, 2008 at 6:17:36 AM
Text In Design Options
Fri, May 28, 2010 at 3:25:07 PM
Page generation time: 1.5415
