Forums >> Community >> The Studio >> Revit bring into 3ds Max
Sat, Apr 9, 2005 at 5:32:35 PM | Revit bring into 3ds Max
justinmthomas2003
I have heard that 3ds Max 7.5 will be able to bring in Revit file... I might have heard wrong, but if that's true, I wonder how?.... I mean what will 3ds max bring in from Revit? It'd be great to use 3ds Max for rendering Revit building. Other thing, I have read from some website saying that Revit 8 will go into 3ds Max, is that true? I'm not sure if I read it correctly. If so, how does Autodesk manage to be able to bring Revit 8 file into 3ds Max? Anyway, that has been on my mind, and I wonder if anyone knows more about it. I'd love to know. Thanks, Justin
Sun, Apr 10, 2005 at 4:01:57 PM | RE: Revit bring into 3ds Max
skisouth
5 Stars: 3 Votes
Currently, Revit files are linked via exported dwg files and imported into Viz 2005. This link is to maintain materials only. The geometry is controlled by the originating software (Revit). You can generate new geometry in Viz, but that geometry will not go back to Revit (via the link). You can export and reimport into Revit - but that defeats the purpose. The idea is to generate the geometry in Revit, then in Viz or Max assign materials, lighting, envoirnments etc for rendering. All changes geometry changes should be made in Revit, then upon re linking to the dwg file from Revit. Currently this is accomplished with basically a plugin for Viz 2005. Viz 2006 and Max 7.5 will not require the plugin. How the software links currently is how the software at this time will continue to work. (it does not read native Revit files) Post edited on 2005-04-10 16:06:09
Sun, Apr 10, 2005 at 5:58:12 PM | RE: Revit bring into 3ds Max
timus777
Were can you download the plugins? Thanks, Tim
Sun, Apr 10, 2005 at 8:53:34 PM | RE: Revit bring into 3ds Max
skisouth
5 Stars: 3 Votes
The plugin is available on your subscription download page. It is for Viz 2005 only. (will not work with Max)
Mon, Jan 28, 2008 at 4:07:02 PM | Revit bring into 3ds Max
epinkel
I was at Autodesk University and I saw a demo of REvit to Max via nPower software's Power Translator. It was pretty cool because it imported the model as a solid not a polygon mesh, so there was no data loss. Also, I noticed that you couuld send models back to Revit.
www.npowersoftware.com
Eric
Mon, Jan 28, 2008 at 4:21:48 PM | Revit bring into 3ds Max
epinkel
I found a link to the power translator Demo. I can't find anything on the site about it but they said it was comming out soon.
here is the movie link
http://www.integrityware.com/eee/02_Revit_To_Max_demo_3/02_Revit_To_Max_demo_3.html
Sat, Mar 28, 2009 at 3:41:31 PM | Revit bring into 3ds Max
echo1
Sorry to light up an old thread, but I saw an autodesk webcast recently where they exported revit to 3D max for rendering and photometric analysis.  The instructor said to export to a file type OTHER THAN the 3d Studio one (FBX) for better results, but now that I am trying to do it, I can not recal which file type it was.  Does anyone know?
 Thanks - Echo
Sat, Mar 28, 2009 at 4:00:40 PM | Revit bring into 3ds Max
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
FBX is the best method if you don't want to have resetup all the materials...
Otherwise its via DWG
Regards,
Chris.
Sat, Mar 28, 2009 at 4:38:03 PM | Revit bring into 3ds Max
echo1
Thanks Mr. Spot
Tue, Apr 14, 2009 at 10:42:56 AM | Revit bring into 3ds Max
sgray28
Does anyone know how to get 3d Max to read rpc content from Revit??
Tue, Apr 14, 2009 at 10:56:11 AM | Revit bring into 3ds Max
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi sgray28, try with this: http://www.archvision.com/rpcplugins.cfm
Tue, Apr 14, 2009 at 10:56:43 AM | Revit bring into 3ds Max
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
it does but you have to purchase the plugin from archvision now or they render with a watermark
Tue, Apr 14, 2009 at 11:34:11 AM | Revit bring into 3ds Max
#13
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Yeah alabaster, that´s the sad part of this......
Tue, Apr 14, 2009 at 11:56:50 AM | Revit bring into 3ds Max
#14
alabaster2513
3.5 Stars: 25 Votes
yeah it kind of pisses me off, didnt it use to be free or am i just on crack?
Tue, Apr 14, 2009 at 12:53:24 PM | Revit bring into 3ds Max
#15
erland73
erland73 Avatar
4.5 Stars: 85 Votes
alabaster, I don't know what's your e-mail so I could send to you a link for this, if you want....
How do you bring revit into 3ds max
Sun, Feb 25, 2007 at 7:20:36 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:53 AM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
Intermediate Revit user here looking for advice on 3ds max [ 1 2 ]
Thu, Sep 8, 2011 at 3:41:35 PM
18
Best Reference to Rendering Revit Models in 3DS Max
Mon, Oct 31, 2011 at 11:00:38 AM
Page generation time: 2.1968
