Forums >> Revit Structure >> Technical Support >> structural beam system visibility
Wed, Jun 25, 2008 at 10:39:58 AM | structural beam system visibility
edamaso
I'm having an issue with seeing joists that i've created using a structural beam system.  The joists do not appear in section/ elevation.  I can create an individual beam which will show up.
Also, another issue i'd like to workout is that I'm trying to use the wood truss as an option for the beam type in the structural system.  What do I have to do in order to get that to be an option in the structural beam system.
Any help would be appreciate.
Thanks
Thu, Jun 26, 2008 at 4:21:18 AM | structural beam system visibility
MartinGT
1 Stars: 1 Votes
Go inot the view you cant see them in and type vv or vg (this brings up visibility graphics)
scroll down and if Structiral Beam Systems isnt ticked, tick it and you should see Smile
If it is ticked then are you sure its a beam system you have drawn?
Thu, Jun 26, 2008 at 6:46:24 AM | structural beam system visibility
edamaso
I figured it out.  When I create the structural beam system the default doesn't check the 3d option which actually creates a 3d model of the joists (this is why they weren't showing up).   The other thing though is getting a wood truss to show up as an option for a beam type.  Does anyone know how to do this???
Fri, Jun 27, 2008 at 12:24:51 PM | structural beam system visibility
AudiHaus
You will have to load the family type inorder to be able to pick it in a project.
Beam System Visibility
Wed, Mar 22, 2006 at 9:23:08 AM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
structural beam system irregularity
Fri, Dec 19, 2008 at 3:03:10 PM
Structural beam system visibilty
Mon, Jan 28, 2008 at 6:08:26 PM
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:02 AM
Page generation time: 0.4406
