Forums >> Revit Building >> Technical Support >> Ceiling Grid Demo & Existing Patterns
Tue, Jun 24, 2008 at 6:28:59 PM | Ceiling Grid Demo & Existing Patterns
cgibson
I am trying to figure out how to make the pattern on one ceiling to show as dashed while all of the other simolar ceilings remain constant. I was able to import the pattern file that allows me to show the ceiling tiles dashed but when I change the pattern in my new compound ceiling type 2'x4' ACT System Demo it changes the original 2'x4' ACT System too. Am I going about this the wrong way?
Tue, Jun 24, 2008 at 7:45:25 PM | Ceiling Grid Demo & Existing Patterns
mhans
3 Stars: 10 Votes
Make a duplicate of your original ACT ceiling. When you are editing the ceiling properties, don't forget to duplicate the material before editting it. If not, the same material assigned to your original ACT and your new ACT will be the same.
Motto: "No Post left behind"
Wed, Jun 25, 2008 at 8:05:33 AM | Ceiling Grid Demo & Existing Patterns
cgibson
Fabulous - Thanks.
So not only should you duplicate the ceiling family type but also under its structure you have to create a duplicate material to asign to your new ceiling family. Otherwise you are editing the material that is asigned to the original ceiling.
HOW DOES ONE SHOW EXISTING CEILING GRID GRAYED OUT, AND THE NEW CEILING IN BOLD?
Fri, Aug 1, 2008 at 9:38:17 AM
Ceiling Grid - Demo Phase
Thu, Dec 15, 2011 at 3:03:40 PM
New light fixture blocks out grid lines on DEMO RCP! Anyone know why?
Sat, Aug 2, 2008 at 12:15:05 PM
Existing Ceiling Grid being partially replaced
Thu, Aug 21, 2008 at 6:54:43 AM
Ceiling grid lines will not show in the "existing" phase
Thu, May 14, 2015 at 8:14:52 AM
Page generation time: 2.7667
