Forums >> General Discussion >> Revit Project Management >> Structural engineer sharing a file with Architect
Tue, Jun 24, 2008 at 10:43:18 AM | Structural engineer sharing a file with Architect
bluedog1
bluedog1 Avatar
We are a medium size structural engineering firm about to start our first project in RST 2009 along with an architect starting their first project in revit.
I would appreciate some help for the following questions;
Do we need to set up a central file since we are working in seperate offices? I am guessing not.
From what I have read the simplest way to share a file if to big to email is through an ftp site. Correct?
This project is an existing multi-story brick warehouse being transformed into lofts/retail. Would it be possible to take the architects model(walls, floors, etc,) and add structural elements (beams, framing columns, landing slabs, etc), or do I also have to create the same walls and floors in my model? (as i type this, I am thinking what a dumb question), I don't want to complicate the process, or do more work than I have to.
Thanks
joe
Tue, Jun 24, 2008 at 11:23:52 AM | Structural engineer sharing a file with Architect
If multiple people are working on the project in the same office, that office will need a central file.  This will be true in each office.
Each office will have their own file but will link a copy of the other's model and copy/monitor appropriate items from the other's file.  This transfer can be email but FTP does work best.
Spend some time learning the copy monitor process.  Not everything needs to be copy/monitored since you can see evrything in the link.
Best way to share file with structural engineer
Wed, Aug 20, 2008 at 6:07:27 PM
Revit 2015 - Architect/Engineer Wet Stamp
Thu, Oct 30, 2025 at 3:15:50 PM
Spotting "Negative Clashes"
Wed, Nov 13, 2013 at 9:59:29 AM
Architect is using ArchiCAD Structural Consultant using Revit?
Thu, Nov 27, 2008 at 11:23:30 PM
Linking Building & Structure Models
Tue, Mar 27, 2007 at 12:03:51 PM
Page generation time: 1.4473
