15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> how to draw objects in the right scale?
1 Posts No Rating |
4 ex: when i draw a door in a new project family, i'd like to have it drawn in the right way every time a changed scale in my project. as you now...a door in a 1:100 scale has to be drawn in a different way and with a different number of lines from a 1:200 or 1:50 scale. how can do that?
can i already draw the right kind of representation when i design a new family?
by sku
Each element in a family can be set to be visible at different levels of detail by select it and looking at its visibilty settings. For instance you might only want the object to display at coarse detail, then at medium detail you'd set the model elements to display and fine detail you might have some embedded detail components you want to display.
Different scale views can be setup to have different detail levels or they can be changed manually in the view properties.
HTH.
How to Scale Objects in Revit |
Fri, Aug 25, 2017 at 1:13:47 PM
Draw order furniture/walls |
Thu, Mar 30, 2017 at 6:51:28 AM
How do you handle dimensioning not-to-scale stuff in Revit? |
Mon, Aug 15, 2011 at 2:30:05 PM
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
Detail scale size |
Fri, Feb 6, 2009 at 12:02:39 PM
