Forums >> Revit Building >> Technical Support >> question on groups for units
Mon, Jun 23, 2008 at 2:42:21 PM | question on groups for units
lunchtrayrider
3.5 Stars: 7 Votes
okay so i hoping someone can take a quick crack at an answer on this.  I have a co-worker who decided that it would be a great thing to group exterior windows in a unit plan group but not the exterior walls.  The reasoning behind this is means for an entirely different discussion however.  I am now trying to correct excluded group member issues along with items being associated with different levels yet being in the same group.
my current problem is when I go into group edit mode it pulls in the exterior walls that the windows (and doors) are in even though they aren't actually in the group. then when reloading it then shows those items in the project.  then I get walls in walls and all kinds of crazyness.  is there a way to prevent this from happening? (prevent the walls from coming in not prevent my co-worker from touching a computer)
Mon, Jun 23, 2008 at 3:23:14 PM | question on groups for units
Hosted elements and groups act funny.  If you export a hosted element, the host will export.  However, if you copy to clipboard and past, you will see that there is a temporary host that goes away after the hosted elements find the right host.
Mon, Jun 23, 2008 at 3:28:29 PM | question on groups for units
lunchtrayrider
3.5 Stars: 7 Votes
what im really trying to do is remove elements that are excluded but yet that I can't unexclude in order to delete.  The only way i know to do this is to right click the group in the project browser and then click edit opening the group edit mode.  then when I bring it back into the project and replace the group it brings in more stuff and then I get walls on top of walls.  Its basically a problem created by trying to fix another problem.
Mon, Jun 23, 2008 at 4:03:19 PM | question on groups for units
NOTE that I said if you export a group, you get the host elements.  THAT is what it sounds like you did.  place the goup somewhere else in you project .... without walls there, then you will get the group with walls that you can now remove from the group.
Mon, Jun 23, 2008 at 4:09:30 PM | question on groups for units
lunchtrayrider
3.5 Stars: 7 Votes
oh now i see, sounds like that will work fine.  thanks wwhub. oh and congrats on your new moderator status.
Mon, Jun 23, 2008 at 4:39:31 PM | question on groups for units
Well the status doesn't give me any rich rewards or even status.  All of the moderators do this because we recoginize that we all gain from the questions and answers on this site.
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:13 AM
Revit 2008 Groups
Tue, Apr 17, 2007 at 2:08:31 PM
Tags for model groups?
Wed, Jan 27, 2010 at 10:13:36 AM
Groups - Copy / Placing
Wed, Aug 16, 2017 at 9:52:27 AM
Groups and Phases
Thu, Jan 29, 2015 at 10:45:27 PM
Page generation time: 0.3220
