Forums >> Revit Building >> Technical Support >> titleblock image
Mon, Jun 23, 2008 at 11:03:07 AM | titleblock image
edamaso
I'm trying import an image as a part of a title block family that I have started.
Does anyone know how to add visibility parameters to imported images?
Because i have our cover sheet, and title block in the same family and there are no visibility settings for images, the raster image appears on every sheet with a title block.
 Any ideas?
Thanks in advance.
Mon, Jun 23, 2008 at 2:09:04 PM | titleblock image
Make two seperate families!
Tue, Mar 3, 2020 at 10:10:13 AM | titleblock image
hanbyjm
"Make two separate familes!"
Make another titleblock family with the image? Then do you insert the second family in the titleblock family or the project?
UPDATE: Just found this. https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Controlling-visibility-of-architectural-stamp-in-title-block.html
Edited on: Tue, Mar 3, 2020 at 10:23:06 AM
Tue, Mar 17, 2020 at 9:10:48 PM | titleblock image
lorraine222
image manager to insert.
JPEG image from titleblock not showing...
Thu, Mar 22, 2012 at 3:11:26 PM
How do I print a Render image on a titleblock??
Thu, Mar 22, 2012 at 3:09:17 PM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Image Missing From Titleblock Once Printed
Wed, Apr 11, 2012 at 8:57:20 PM
How to embed an image into a titleblock?
Tue, Jan 25, 2011 at 11:22:19 AM
Page generation time: 0.2038
