Forums >> Revit Systems >> Technical Support >> Surface area of sweep?
Mon, Jun 23, 2008 at 1:16:50 AM | Surface area of sweep?
schuss
I am very new to revit, and was asked to make a very complex roof, basically made out of multiple flat panels.  I roughted it for the moment using solid sweeps, and simply moved and rotated the panels in place.  Is there any way I can get Revit to work out the surface area of each of these sweeps?
Mon, Jun 23, 2008 at 3:57:03 AM | Surface area of sweep?
4 Stars: 205 Votes
Can you put some images to figure it out?
Mon, Jun 23, 2008 at 5:46:41 PM | Surface area of sweep?
schuss
Posting an image wont help. I simply need instructions to work out the surface area of a triangluar shaped sweep.
Oh, I think I posted this in the wrong subject, and should be in Revit Building Technical Support.  Any way this can be moved over there?
Adding different materials to a sweep surface
Wed, Jun 8, 2016 at 11:51:49 AM
Material surface pattern on a solid sweep?
Wed, Nov 17, 2010 at 2:48:49 PM
column surface area
Tue, May 16, 2017 at 6:33:15 AM
images are showing area surface patterns through them
Tue, Dec 10, 2013 at 3:40:41 PM
Revit 2015, Curved Wall Sweep Model Surface Pattern Inconsistant
Tue, Apr 28, 2015 at 4:09:13 PM
Page generation time: 2.7851
