Forums >> Revit Building >> Technical Support >> insertion points
Mon, Jan 19, 2004 at 8:46:45 AM | insertion points
Bimman
Bimman Avatar
1 Stars: 2 Votes
i know in revit they are called origins, but how do i set them. what i have going on is a piece of window trim that i need to set they insertion point at an iside corner of the trim so i can place it over a window by picking the same outside corner of the window. i know you can create windows with trim but for now i chose to do them apart.
PWD
Mon, Jan 19, 2004 at 9:14:30 AM | RE: insertion points
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I don't understand, when you build a family the origin is the insertion point...
Hiroshi Jacobs
The Catholic University of America
Mon, Jan 19, 2004 at 9:21:28 AM | RE: insertion points
Bimman
Bimman Avatar
1 Stars: 2 Votes
i made my 1X6 window trim from the genric wall hosted family. when i go to insert the trim over the window i can't snap to the window corner. i have to insert in the project then grab the corner of the trim and then move it to the corner of the window to place it where i want it. i was trying to elimante placing it then having to move it to where i need it, by just being able to insert it at the exact spot needed
PWD
Mon, Jan 19, 2004 at 1:43:12 PM | RE: insertion points
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I don't know if you can...would be interested if anyone else had insight on this.
Hiroshi Jacobs
Revit Export Block Insertion Points
Fri, Oct 2, 2009 at 2:16:39 AM
Multiple Insertion Points in Generic Annotation Family
Tue, Mar 4, 2014 at 10:01:01 AM
Export insertion point???
Thu, May 4, 2006 at 2:31:08 AM
Insertion Point of Custom Titleblocks / Title Blocks
Tue, Oct 13, 2009 at 2:57:30 PM
Topographic points
Thu, Nov 27, 2008 at 9:22:44 PM
Page generation time: 0.7141
