Forums >> Revit Building >> Technical Support >> RAC2008 clean uminstall
Sun, Jun 22, 2008 at 7:00:06 AM | RAC2008 clean uminstall
emosms
Hallo
I just uninstaled revit 2008 and put 2009 to give it a try. I removed manually all related folders i could find about, i deleted all keys related to revit 2008 in the registry editor. And i have a problem.Each time a start another program (in my case it is Build Desk energy design, a program for heat loss calculations) i have some revit 2008 installer starting.After i cancel  the revit2008 installer my program starts and then fails.I got a message run-time error 13, type mismatch.How can i clean uninstall revit 2008? It is allready uninstalled, but still smth remains.
Best Regards
RAC2008
Fri, Sep 7, 2007 at 2:41:18 PM
Problem with Curtain wall Mullion clean up at corners
Mon, Apr 7, 2008 at 9:53:09 AM
Clean cut below stairs.
Fri, Nov 30, 2007 at 8:56:15 AM
Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 1:19:19 PM
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:24 AM
Page generation time: 0.5270
