Forums >> Revit Building >> Technical Support >> Revit Links-visibility
Fri, Jun 20, 2008 at 4:43:50 PM | Revit Links-visibility
jchan
I am having trouble with the visibility of a link that I have in my drawing.
I want the room names to show up from the link, however, when I go to my visibility settings, go to revit links, custom display settings, and annotations, it shows that everything is all checkmarked and visible, when in fact, it really isn't showing.
Any suggestions? Please help!
Thank you!!
Thu, Jun 26, 2008 at 10:54:29 AM | Revit Links-visibility
mlohr
mlohr Avatar
Do the Room Tags show up in the "Reveal Hidden Elements" view (lightbulb along bottom of view)?  sorry i only have a question and not an answer...
Fri, Jun 27, 2008 at 10:45:37 AM | Revit Links-visibility
TABEST
4 Stars: 4 Votes
check the phase in which he rooms were created, they only show up in current phase, so if you are in the "new construction" phase, and your room tags were placed in "existing" then you'd not be able to see the "existing" room tags.
Wed, Aug 25, 2010 at 9:11:45 AM | Revit Links-visibility
snutz82
Here, I just learned this yesterday.  I will attach a word document that should walk you through this process.  Unfortunately all annotative information that is related to this link will show up and to this point I have not figured out how to turn only some of it off.
Linked Revit Models and Visibility
Sat, Jun 11, 2011 at 8:41:54 AM
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
MANAGE LINKS
Tue, Nov 10, 2009 at 7:41:25 AM
visibility for links question
Tue, Jan 10, 2017 at 8:41:35 AM
Save to Central or Revit Links
Tue, Sep 4, 2007 at 2:56:57 PM
Page generation time: 1.3007
