Forums >> Revit Building >> Technical Support >> Yes/No visibility parameter
Fri, Jun 20, 2008 at 11:22:44 AM | Yes/No visibility parameter
Fukudome
1 Stars: 1 Votes
I am using Revit 8.1.  I am setting up a generic annotation family of an architect stamp. I want to add a family parameter (graphics heading) that allows the user to turn on or off the visibilty of the family when loaded into the project. So far, I have created the parameter, it shows up as a check box in the element properties when loaded into the project, but it DOES NOT control its visibilty.  Is there a formula I should be using, or what else am I doing wrong?
Fri, Jun 20, 2008 at 12:43:16 PM | Yes/No visibility parameter
For having items turn on and off within a family, this can be used but but you want to turn on or off the entire family and this is not a good way to do it.
If you want to do it this way, then make the stamp be part of your sheet family.
    -Then set your yes/no parameter as an instance based parameter there.
    -Now, draw all of your stamp line work.  Select all of it and open the properties for these items.
    -In the element properties box, under graphics - visible, there is a button clear to the right.
    -Select that and you will see another pull-down where you pick your yes/no parameter.
Fri, Jun 20, 2008 at 1:24:11 PM | Yes/No visibility parameter
Fukudome
1 Stars: 1 Votes
ahhh...I knew I wasnt doing something right.  works like a charm.
Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
Wed, Mar 7, 2012 at 5:53:46 PM
Mon, Jan 5, 2009 at 5:31:26 PM
Dimension parameter based on visibility
Tue, Sep 22, 2009 at 3:42:59 PM
EXTRUSION YES/NO PARAMETER
Mon, Apr 28, 2014 at 4:04:36 PM
11
Visibility Parameter in Room Tag
Fri, Jun 4, 2010 at 6:01:09 PM
Page generation time: 2.3781
