Forums >> Revit Building >> Technical Support >> REVIT & 3D MAX DESIGN
Thu, Jun 19, 2008 at 11:31:00 PM | REVIT & 3D MAX DESIGN
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
  WHEN I EXPORT TO 3DS FROM REVIT IT COMES IN WITH MATERIALS NOT SO RIGHT. BUT WHEN I IMPORT A REVIT FILE SAVE AS A .DWG IT COMES IN TO 3DS WITH GOOD MATERIALS,  I THOUGHT ITS BETTER TO EXPORT A REVIT FILE DIRECTLY TO 3DS, WHAT AM I DOING WRONG     THANKS
Fri, Jun 20, 2008 at 3:05:17 AM | REVIT & 3D MAX DESIGN
Elmo
3.5 Stars: 4 Votes
3DS does not take Revit's materials for some odd reason you have to re-assign the materials inside of 3DS. I have yet to find another method that allows for better transfer.
Sun, Jun 22, 2008 at 7:26:30 PM | REVIT & 3D MAX DESIGN
mtyp
Have you tried the .fbx Export?  Its avialable in 2009.  We had a quick play with it and it appears to bring the materials across.
Mon, Jun 23, 2008 at 3:49:08 AM | REVIT & 3D MAX DESIGN
4 Stars: 205 Votes
Hi, MTYP has right, export with FBX....
Mon, Jun 23, 2008 at 10:36:34 AM | REVIT & 3D MAX DESIGN
DESIGN4BUILDING
3.5 Stars: 3 Votes
iv tried that,  2009 has a direct export to .fbx and 3dmax but i get a warning states that lighting and materials are not mental ray , im useing 2009v 3dm design and 2009v revit arch.
Tue, Jun 24, 2008 at 4:02:48 AM | REVIT & 3D MAX DESIGN
4 Stars: 205 Votes
hi, it's because MAX don't recognize some materials, lights and RPC from Revit, in MAX you must change them...
Tue, Oct 21, 2008 at 10:09:25 AM | REVIT & 3D MAX DESIGN
rgordon
We have been switching from ADT over to Revit.  The Revit stuff is working great... now we are gearing up for rendering our Revit drawings in Max Design.  I have exported our revit model using both FBX and DWG.  We aren't planning on using our Revit materials in Max, we have libraries of materials from Viz, and will probably upgrade our materials to take full advantage of MR.  In other words, all we need is Revit to have a place holder for the materials...
So, here is my question.  It seems the DWG link with Revit and Max Design works better than the FBX link.  What is the advantage of the FBX link?  Why would I use it over the DWG link?
Tue, Oct 21, 2008 at 10:17:58 AM | REVIT & 3D MAX DESIGN
KingRevit
4 Stars: 12 Votes
FBX file format passes rendering information to 3ds Max, including lights, render appearances, sky settings, and material assignments for the 3D view
dwg cant do the above
Tue, Oct 21, 2008 at 11:46:44 AM | REVIT & 3D MAX DESIGN
rgordon
Thanks...  since my scenes are setup for Max, most of that I don't need to bring over from Revit anyway (cameras, lights etc..).  We model our sites using other programs.  DWG does bring over material assignments (and in my opinion does a better job of it than FBX).  I guess when we do some interior renderings, I might consider using FBX instead.
Intermediate Revit user here looking for advice on 3ds max [ 1 2 ]
Thu, Sep 8, 2011 at 3:41:35 PM
18
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:25 PM
3DS Max Design training in Brisbane
Mon, Jan 5, 2009 at 4:39:41 AM
3ds Max Design Gunslinger, looking for Revit users
Wed, Aug 27, 2014 at 9:34:30 AM
Revit vs 3ds Max in Interior design (Furniture)
Sun, Aug 21, 2016 at 1:56:51 AM
Page generation time: 2.1587
