Forums >> Revit Structure >> Technical Support >> draw beam between foundations
Thu, Jun 19, 2008 at 12:32:31 PM | draw beam between foundations
DaveF
Hi
RS '08
It's been a while since I last used revit & I've forgotten a lot.
In the attached, how do I draw a GB1 between the midpoints of the two pilcap foundations?
I can't get it to snap.
Am I using the correct type of beam? I created the pilecap families so there could be something wrong with them.
Also as the pilecap is deeper than the beam i thought there would be dashed lines at their joint. Any ideas how to achieve that?
Hope you can help
Cheers
Dave F.
Thu, Jun 26, 2008 at 3:40:53 AM | draw beam between foundations
MartinGT
1 Stars: 1 Votes
Dont use the ground beam family, I dont know why its in the library to be honest.
Instead use the concrete beam and edit to suit your ground beam size accordingly, then you can draw from snap to snap.
Hope this helps
Mon, Jul 7, 2008 at 7:58:21 AM | draw beam between foundations
DaveF
Hi Martin
Thanks for the reply.
I maybe wrong but I think Ground Beams don't have any analysis info & don't get exported to the likes of Robot.
I'm still at a loss how to solve my prblem.
Ta
Dave F.
Mon, Jul 7, 2008 at 8:48:26 AM | draw beam between foundations
MartinGT
1 Stars: 1 Votes
Dave, you can change how each element is anylised, I.e Foundations etc
Have a bash and export it to your design software is the only thing I can suggest.
Let us know how you get on.
Martin
Trouble with Valley Beam
Thu, Dec 2, 2010 at 11:33:55 AM
Joining isolated foundations to concrete beams - 2009
Thu, May 7, 2009 at 1:43:52 AM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
Steel beam connection with structural wall
Fri, Mar 1, 2013 at 9:06:41 AM
Brick Corbelled Foundations
Mon, Aug 9, 2010 at 8:46:12 AM
Page generation time: 0.4352
