Forums >> Revit Building >> Technical Support >> Using families from Steel Select.com
Wed, Jun 18, 2008 at 10:04:20 PM | Using families from Steel Select.com
ldrake
Hi, I saved a bunch of families from steel select.com and try to apply them in Revit. I loaded them in and quiet easily applied the gutter types under the properties tab and under edit/new construction - profile. but I dont know how to apply the roofing familes. When I load it into the drawing it comes up under families-profiles in the project browser so I can turn the gutter into roof sheeting but dont know how to apply it to a roof???? any help would be great!!!
Thu, Jun 19, 2008 at 3:43:20 AM | Using families from Steel Select.com
4 Stars: 205 Votes
Hi, you can add gutter to a roof by "Modeling - Host Sweep - Roof Gutter (or Fascia, if you want to)"...
Thu, Jun 19, 2008 at 7:15:33 AM | Using families from Steel Select.com
Look in your help menu using "profile" to learn how this family is used in several applications and how to use it.
Steel connection plates families
Fri, Jun 21, 2013 at 1:43:40 AM
Fabsec Steel Beam Families
Wed, Nov 8, 2006 at 1:43:28 PM
Problems opening pre-loaded steel families in Revit Structure 2012
Tue, Sep 10, 2013 at 10:26:36 PM
sloped steel?
Thu, Apr 8, 2010 at 5:51:25 PM
Piping families...
Mon, Oct 22, 2018 at 9:20:59 AM
Page generation time: 0.4315
