Forums >> Revit Building >> Technical Support >> Opposite formula
Wed, Jun 18, 2008 at 11:10:53 AM | Opposite formula
KingRevit
4 Stars: 12 Votes
Hi I am terring to create a formula for the visibility of a family. So far I have a yes/no paramater for approved <APPROVED> or not approved. I have another yes/no paramater the visibility of the family <VISIBLE>. I would like if I ticked (yes/1) for APPROVED then the VISIBLE would be Un-Ticked (no/0). how do I write this in a formula.
I know its probably simple and i have tried what i can but don't be able to get it too work.
I have tried
IF (APPROVED=1,1,0)
APPROVED>1
APPROVED<0
Thanks in Advance.
Wed, Jun 18, 2008 at 11:19:04 AM | Opposite formula
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Set one to "not" equal the other.
ie.
Value                     Formula
Approved               =
Not Approved         =  No(approved)
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Jun 18, 2008 at 11:19:44 AM | Opposite formula
brettgoodchild
4 Stars: 17 Votes
That's supposed to be not (Approved)....having a bad typing day
                             ~ Abraham Lincoln
Wed, Jun 18, 2008 at 11:24:34 AM | Opposite formula
brettgoodchild
4 Stars: 17 Votes
I wrote a better example of this in another post on here...I think it was called yes/no parameters or something like that.
                             ~ Abraham Lincoln
Thu, Jun 19, 2008 at 5:27:47 AM | Opposite formula
KingRevit
4 Stars: 12 Votes
Hi still cant get this to work maybe I overcomplicated my first post
All I want to do is have 2 paramaters
<p1> & <p2>
both are yes no paramaters.
If I tick <p1> I want <p2> to be unticked. Sounds simple! but finding it imposible.
Any more help would be much appriciated.
Thanks.
Thu, Jun 19, 2008 at 7:20:05 AM | Opposite formula
Elmo
3.5 Stars: 4 Votes
You dont need a third parameter to control this. As Brett said all you need to do is inside your one parameter at the formula place type not(p1) and it should do what you want.
Thu, Jun 19, 2008 at 9:19:25 AM | Opposite formula
KingRevit
4 Stars: 12 Votes
thank you thank you thank you
NOT
this is all you have to place before the name of another paramater which is in brackets.
Sorry my dislexcia made me not understand brett.
revit help can be so crap as nowhere to do with scheluing doesa it say you can use <not>
 knew it would be simple. i will give u both 5 stars.
Thank you.
Thu, Jun 19, 2008 at 9:23:46 AM | Opposite formula
KingRevit
4 Stars: 12 Votes
i actually meant thank you. the not after the thank you was to do with the paramater controler.
Fri, Jun 20, 2008 at 3:46:44 AM | Opposite formula
Elmo
3.5 Stars: 4 Votes
The information is in the help file but it wont be under scheduling. It will be under the formula section.
yes/no and if/then
Fri, Oct 17, 2014 at 1:58:37 PM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
need help with a formula for my calculated value
Thu, Jan 30, 2014 at 1:03:02 PM
Page generation time: 0.7389
