Forums >> Revit Building >> Technical Support >> Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
Tue, Jun 17, 2008 at 3:33:04 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
rquist
"Can't make type "Andersen_Csmt_Dbl_CR25_CW255_1679[1] : CW25"."
 Keep getting this message everytime I try to insert the Andersen windows that I just downloaded.
I thought it had something to do with the head the element properties dialog box and the defines origin check box but, that didn't help.  I tried inserting the windows in plan view and also from a 3D view to ensure that the wall was tall enough.  I didn't check all the windows, I downloaded a lot.  I tried six of them and I get the same error message.
 thanks for any suggestions
Randy
Tue, Jun 17, 2008 at 3:37:44 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
4 Stars: 205 Votes
Hi, can you put one of them here to i can download and see what happen?
Tue, Jun 17, 2008 at 3:40:42 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
kesflower
3.5 Stars: 11 Votes
I haven't had much luck with those Anderson window families either.  2009 didn't solve the problem.  I reverted to simpler window families that I found here and use drafting views to include the detail that the sections need.
if anyone else knows a way to fix them, I'd love to hear it too.
Ruth Rau
Main Street Architecture, P.C.
Tue, Jun 17, 2008 at 4:31:39 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
rquist
KIND OF NEW TO ALL OF THIS.
IS THERE A WAY TO UPLOAD THE WINDOW(S) IF I CAN'T INSERT IT INTO A WALL?
AMONG OTHERS, I WAS TRYING TO INSERT A CW25 UNIT THAT WAS AVAILABLE ON REVIT CITY.
Tue, Jun 17, 2008 at 4:40:59 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
4 Stars: 205 Votes
Hi RQUIST, i don't try to KEEP with "YOUR" window if that's what do you imagine, i just don't have time to Search to those windows, i guess i have here all of them but ok!!! good luck
By the way, "THERE A WAY TO UPLOAD THE WINDOW(S) IF I CAN'T INSERT IT INTO A WALL?" - awnser=YES, in the "File Attachments" you can put images or .RFA elements or what do you want....
Edited on: Tue, Jun 17, 2008 at 5:18:21 PM
Wed, Jun 18, 2008 at 1:59:18 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
4 Stars: 205 Votes
"KESFLOWER" this is the problem of this type of windows "Andersen" see  the  video:  http://screencast.com/t/IHrx6eo9otj
Thu, Jun 19, 2008 at 10:16:54 AM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
rquist
THANK YOU EVERYONE
 I'LL DIGEST THE INFO AND SEE IF I CAN GET IT WORKED OUT
RANDY
Thu, Jun 26, 2008 at 9:33:25 AM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
rquist
Hi Typhoon:
Thanks for the video. Finally got a chance to look at it.
How can I open the suspect window drawing file, in order to follow along with the tutorial?
I'm not sure how to access the window for editing if I can't insert it into a drawing.
This is probably basic but only recently have I been able to make a full-time job of working with Revit. Needless to say, I'm looking forward to it.
Thu, Jun 26, 2008 at 9:36:58 AM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
rquist
figured it out.   I knew it was going to be simple
Wed, Jun 23, 2010 at 3:49:20 PM | Can't Place Recently Downloaded Windows from Revit City: Revit Architecture 2008
shellp2
I am having this same problem.  I have used these Andersen Windows for years and now just updated to 2011.  I can't get them to work.  I even downloaded a new file and fixed the orgin and still can't place them.  How did you figure it out?  Help!
--New Revit MEP 2008 User--
Tue, Sep 25, 2007 at 1:06:09 PM
Loading families from revit city
Thu, Mar 7, 2013 at 1:28:30 PM
Revit City stuck on 'About Us' page
Wed, Jan 20, 2016 at 7:53:46 AM
Can't open SOME Revit 8 files with Revit 2008
Mon, Jul 9, 2007 at 9:33:05 AM
Can't place some components without creating floors (REVIT Architecture 2013)
Fri, Dec 14, 2012 at 2:49:55 AM
Page generation time: 1.8545
