Forums >> Revit Building >> Technical Support >> Exporting Revit 2009 Sheets to CAD
Tue, Jun 17, 2008 at 9:10:51 AM | Exporting Revit 2009 Sheets to CAD
jeffe28
I have Revit sheets set up that I want to export to Cad 2004, but when I export, the sheet border and text are only visible in paper space.  Also, the text is highlighted with black that will not go away.  How would I get the sheet to export to model space?
Tue, Jun 17, 2008 at 9:22:14 AM | Exporting Revit 2009 Sheets to CAD
ArchWestCY
4.5 Stars: 7 Votes
I am a bit curious why you would want your titleblock in model space.  Please share your idea.
What might be the easiest thing to do is copy and paist the titleblock from Paper space into Model space and Scale it by whatever scale factor the drawing is set to.  Otherwise you would need to draw the titleblock in your Revit View (rather than Sheet) in order for it to export to Model space.
ArchWestCY
Tue, Jun 17, 2008 at 9:47:00 AM | Exporting Revit 2009 Sheets to CAD
jeffe28
We plot from model space, rather than paperspace.  I will go to my revit border file, and export direct from there.  I figured out the text thing; in revit, I had the text background set to opaque, so I switched it to transparent and the text is fine now.
Thank You
Wed, Jun 18, 2008 at 3:53:01 PM | Exporting Revit 2009 Sheets to CAD
jeffe28
I also just learned That I don't have to change each Revit text to transparent, I can just explode it in CAD.
Exporting Sheets and sheets only to DWG
Tue, Mar 27, 2007 at 9:42:22 AM
Exporting mulitple sheets to cad at once
Thu, Feb 25, 2010 at 1:15:43 PM
Shop Drawing requests for CAD bases
Fri, Aug 6, 2010 at 5:03:01 PM
Exporting to CAD from Revit 2012
Mon, Oct 8, 2012 at 7:30:49 AM
Exporting to AutoCAD from Revit 2009
Wed, Jul 16, 2008 at 1:26:08 PM
Page generation time: 1.4699
