Forums >> Revit Building >> Technical Support >> Plan Region in RCP not working
Tue, Jun 17, 2008 at 8:18:12 AM | Plan Region in RCP not working
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
Revit Architecture 2009
We have a 1st level RCP in which there is an area 'OPEN TO ABOVE'. In this open to above area you can see the ceiling of the 2nd level, which we do not want.
I tried using a Plan Region to set the view range. With the view range set to 1ST LEVEL we tried setting the TOP and View Depth LEVEL from 12' to 7'-6" (both were originally set to 44' by default) with no luck, you could still see the 2nd level ceiling.
We tried setting the view to 2ND LEVEL and setting all the numbers to 0'-0", no luck.
Anyone have any idea what we might be doing wrong?
It's got to be happy hour somewhere
Show Furniture in an RCP using Plan Region or Regions
Tue, May 2, 2017 at 8:21:18 AM
Orienting plan regions
Thu, Sep 3, 2015 at 2:59:30 PM
View Range/Plan Region Visibility Controls in RCP
Wed, Feb 1, 2012 at 11:20:32 AM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
family that appears in RCP but not in Plan
Tue, Sep 22, 2009 at 8:31:34 AM
Page generation time: 0.6813
