Forums >> Revit Building >> Technical Support >> RAC2009 - color schemes don't show up
Mon, Jun 16, 2008 at 6:38:20 AM | RAC2009 - color schemes don't show up
jcs001
Hello,
I am using revit 2009
I set up a color scheme, and i assigned it to a plan view just like I always do. I added rooms, and i assigned the color scheme tag to the view.
The areas of the rooms are displayed, however the colors in the rooms simply don't show up. I check Visibility/Graphics, (VG /Model Graphics/Color fill is checked),  I checked everything without success.
Unfortunatly i have to finish my work till tomorrow morning, if anyone knows why this is happening in RAC2009 and how to solve this problem please let me know,
thx in advance
Mon, Jun 16, 2008 at 3:05:20 PM | RAC2009 - color schemes don't show up
mhans
3 Stars: 10 Votes
You have to activate the Color Fill Scheme under Setting pulldown menu. It's very straightforward, you can go per room, per area, per dept, etc.
Motto: "No Post left behind"
Tue, Jun 17, 2008 at 5:21:59 AM | RAC2009 - color schemes don't show up
jcs001
Hello. Thanks for your reply to my post. I have all them activated. The color scheme legend also appears ok, only the room color don't.
Wed, Jun 18, 2008 at 7:47:34 AM | RAC2009 - color schemes don't show up
SteveB
3.5 Stars: 5 Votes
what was the answer to making the colors display on the plan.  Mine are activated in the "settings" pull down (check box "visible"Winking, the legend appears, but the rooms aren't filling with colors.
Wed, Jun 18, 2008 at 8:44:48 AM | RAC2009 - color schemes don't show up
jcs001
"Mine are activated in the "settings" pull down (check box "visible"Winking, the legend appears, but the rooms aren't filling with colors."
 This is precisly what's happening to me...
Wed, Jun 18, 2008 at 4:34:04 PM | RAC2009 - color schemes don't show up
mhans
3 Stars: 10 Votes
You are ask to set the color scheme the first time you insert a Color Scheme Legend. if you choose the default "Department" when click the Color Schem Layout from the Room and Area Browser, you will not have any colors because your rooms are not departamentalize yet. Select Name instead. Then you'll have your colors. Discover!
Thu, Jun 19, 2008 at 5:55:26 AM | RAC2009 - color schemes don't show up
jcs001
 Solved  by the Autodesk certified dealer: the problem was because of the material applied to the floor. On the surface Pattern of the material under graphics tab, I had a color (white). Changing it to <none> solved the problem - all the room colors according to the color schemes now appear correctly.
Thanks everyone for trying to help!
Thu, Jun 19, 2008 at 7:12:25 AM | RAC2009 - color schemes don't show up
You have indirectly pointed out one of the problems members have in answering questions here.  There are many variables that come into play and sometimes they are not very obvious.
Thanks for passing on your discovery so that others will learn from it.
Sun, May 2, 2010 at 10:29:06 AM | RAC2009 - color schemes don't show up
troublony
I had a similar problem b/c I hadn't yet assigned the view a color scheme yet.  To do this:
 select the view _ VP _ Color Scheme  --> select desired color scheme
fear no CAD
Mon, Jun 24, 2013 at 9:04:35 AM | RAC2009 - color schemes don't show up
Thread Post Kudo! Thread Post Kudo! #10
FWASDrafter
FWASDrafter Avatar
To add to this thread I found that in order for my colors to show up I had to turn on the Rooms Color Fill under visibility and graphics settings.
Color Schemes
Thu, May 23, 2013 at 12:35:43 PM
area color schemes
Fri, Jan 27, 2012 at 2:36:28 PM
Color Schemes - Revit 2009
Fri, May 8, 2009 at 12:02:04 PM
"System Color Schemes" not regular color schemes in Elevation or Section views
Mon, Mar 22, 2010 at 6:00:00 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Page generation time: 1.1012
