18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> couple probs in revit on titles
7 Posts No Rating |
Having a couple probs need some help with Basically, on my title sheets, my sheet number is very long due to the convention of how I have to make them, what this means is on the elevation drawings the title on the elevation tags is huge and I carnt make it smaller, so how can I change the text in the elevation tags or how can I add another bit like project number in the titleblock that is changeable per sheet, and not through the whole project, as I carnt make one that is changeable in the project, only in the titleblock family. Cheers guys
Are you talking 2 things here? Sheet No and View Title? Click the view and edit the element properties. Scroll down and you'll find an item called View name and Title on Sheet. View name is the name that appears on your browser. If you don't input anything on the "Title on Sheet", this will going to be your sheet title. you have a choice also not to shot the sheet no. on plan if it becomes crowded. Go to Settings (pulldown menu), View tags, Elevation tags and uncheck Show view name box.
Motto: "No Post left behind" |
Purge unused Viewport Titles |
Thu, Aug 30, 2018 at 10:41:49 AM
11
Disappearing Titles |
Wed, Jun 6, 2007 at 6:14:25 PM
Viewport titles |
Tue, May 9, 2006 at 4:39:09 PM
Turn off view titles |
Tue, Jan 9, 2007 at 4:29:12 PM
A couple of Revitcity.com wishes |
Tue, Dec 6, 2011 at 11:45:55 AM
