17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Editing a Mass to attach to roof.
43 Posts No Rating |
so i have a client that wants to use corigated steel, or aluminum as a siding feature, that sticks out about 2" past the stucco. i figured the best way to accomplish this is to create a mass, and apply a finish to them. well, it worked great, but now i have another problem. as you can see in the picture the masses are sticking through the roof. i am hoping that there is an easy way to edit these to follow the bottom of the roof pitch. anyone have any ideas? they are greatly appreciated Tim
Revit user since 2008. |
I think instead of Mass you can use a wall with built-in reveal/sweep. Just edit the wall profile to shape it accdgly.
Motto: "No Post left behind" |
Correction! you don't need to use built-in sweep/reveal. See attached. Actually, I just use a square profile but you can use a semi-circle or a circular profile to cut you wall. Then a wall can be attached to thr roof.
thanks for the suggestions. i'm not sure i follow what you mean by profile. how did you create the profile? a quick how you did it, would be very helpful. thanks
How to attach top/base - walls to mass roof |
Tue, Sep 22, 2015 at 3:18:05 PM
Curtain Wall Fails to attach to Roof by Face object |
Mon, Jan 25, 2016 at 1:43:02 PM
Attach Wall up to Roof |
Tue, Oct 2, 2007 at 3:57:57 AM
Roof by Face and Wall by face tools |
Tue, Jan 28, 2014 at 6:31:03 AM
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
