8 Users Online (6 Members):
Forums >> Revit Structure >> Technical Support >> Cavity Wall - Cavity Not Filled
Hi Guys Is there way of making a cavity wall so that the cavity isnt filled with anything? I have a cavity wall and in it partially sits a colimn web and flange. Now when I do a section it shows the flange as hidden, even if I sat the cavity as an air barrier? Anyone got anyideas?
Hi MARTIN, can you put some short images to figure out what do you really want? What Version of Revit are you work?
Attached now , the riinged item is my flange of my column, it should be solid and also grey! Using RS 09  Thanks for the help
Hi again, do you sure that zone is a "Air Barrier" and you don't put some hatch or material when you create that wall? Is there a Section View only or a Callout View? you can solve that by going to Drafting and create a Masking Region with "invisible Lines" under that Hidden Lines...
The Construction of the wall is attached. The Air Barrier has no fill pattern for the cut. I have just used the stylus too for now and changed the lines to thin. The detail is in section by the way.
This time attached
Hi MARTIN, when i use Air Barrier in "Function" i put "Thermal Air Layer" and not "Structure [1]" but this not change the problem, you must have some material or pattern in "Cut" in the material "Air Barrier", do you have "None" in Cut Pattern"? check this...
cannot get rid of lines join cavity in wall |
Fri, Sep 12, 2008 at 8:31:29 AM
Joining different Cavity walls |
Mon, Jan 5, 2015 at 12:26:43 PM
Cavity Wall Around Bay Not Showing Correct Detail |
Sun, Jan 17, 2010 at 3:50:13 PM
Cavity wall for Revit 2008 |
Thu, May 26, 2011 at 12:06:42 PM
Column in a cavity wall |
Wed, Oct 24, 2007 at 4:55:44 PM
