Forums >> Community >> Newbies >> View Reference
Fri, Jun 13, 2008 at 9:24:07 AM | View Reference
designrevisions
Can anyone tell me how to edit the view reference tag? I've assigned a view reference tag to a matchline, but it's labeled as REF and I want to change it to the proper sheet number and view. I'm working in Revit 2009. I've searched the help file and it was no help.
Fri, Jun 13, 2008 at 9:50:39 AM | View Reference
If you have split a view using a matchline and dependent views, when you place the views on a sheet, the reference will update automatically.
Fri, May 8, 2009 at 12:26:24 PM | View Reference
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I have my matchline and my two dependant views on each sheet, but it still shows Ref??  Why is that?
Denver, CO
Revit Architecture
Fri, May 8, 2009 at 3:49:55 PM | View Reference
Lorne ... I don't have time right now - mabe next week.  You have done something wrong.  I know it works because I've used it a couple of times.
Tue, May 12, 2009 at 2:18:27 PM | View Reference
jkherm
wwhub, any news on this fix...i too am trying to figure this one out and could use the knowledge.
thanks!
Tue, May 12, 2009 at 2:58:20 PM | View Reference
This is really pretty straight forward.  Did you read your H E L P searching for matchline?  It shows how to create the dependent views, then place the matchline.
And just like most call-out / view tags, you can modify the matchline callout.
Tue, May 12, 2009 at 3:10:54 PM | View Reference
jkherm
Alright, just happened to figure it out a few minutes ago, thanks for the reply, sorry to be a bother!
Have a good one.
Tue, May 12, 2009 at 5:13:45 PM | View Reference
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yes I did read the help dialog first.  I have three views, one overall, and TWO DEPENDANT views.  It still shows as 'ref' and not the sheet reference.  I think I'm doing it the correct way.  Unless I'm missing something.
I open my overal view, turn crop regions on.  Then go to View tab>Sheet Composition panel>Matchline.  I'm then in sketch mode.  I've tried drawing a straight line where both dependent views overlap.  Also tried to draw a straight line with each end sticking into the dependant crop region boundary.  Then I go to Annotate Tab>Tag Panel>View Reference.  When I go to place it, the crop regions highlight and I can't place it.  I cannot highlight the matchline, but when I try to click on it that's when it places the tag that says: "Ref".  They are both on their appropriate sheets.
What did I miss?
Thanks,
Lorne
Denver, CO
Revit Architecture
Tue, May 12, 2009 at 5:14:13 PM | jkherm
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting jkherm from 2009-05-12 15:10:54
Have a good one.
What did you do?  I still can't figure it out?
Denver, CO
Revit Architecture
Tue, May 12, 2009 at 5:19:05 PM | View Reference
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It will display "Ref" when you haven't applied a "View Reference Tag" for the system family to use.
  1. Select the tag and go to element properties.
  2. Edit
  3. From the drop down pick your loaded view reference tag
  4. OK
If you don't have a view reference tag family loaded, load the default one from the metric or imperial library or create your own.
HTH.
Regards,
Chris.
Tue, May 12, 2009 at 5:28:46 PM | View Reference
#11
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
That worked!  Thank you!  I really do apologize for my stupid questions on these forums.  But I get stuck and no one in the office can help.
I appreciate the time all of you take to help others here.  WWHub & Mr. Spot I know you have probably been the one to help me the most.  Thanks.
Lorne
Edited on: Tue, May 12, 2009 at 5:29:16 PM
Denver, CO
Revit Architecture
Thu, Dec 26, 2013 at 11:54:57 AM | View Reference
#12
mhaworks
Thank you for the answers. There is always someone with the same problem. thanks!
Multi-view Elevation - Reference SIM
Fri, Mar 9, 2012 at 8:40:42 AM
Visability of Reference Files
Sat, Nov 12, 2011 at 8:00:03 AM
View Reference center point is too far from the label.
Wed, Nov 19, 2014 at 9:24:13 AM
VIEW REFERENCE FAMILY
Mon, Oct 20, 2008 at 3:29:35 PM
Dual View Reference with Single Call-out
Tue, Mar 8, 2016 at 2:29:34 PM
Page generation time: 0.7633
