Forums >> Revit Structure >> Technical Support >> Viewing sloping beams
Fri, Jun 13, 2008 at 8:19:35 AM | Viewing sloping beams
clarkrob
Hi again :-)
Just wondered if anybody knew of a way to stop Revit cutting sections through angled beams so literally (see attachment)?
You would never draw like that in CAD, instead you would tend to draw a cut through the beam to illustrate that it is there, however allow the plans do that talk with regards to it been angled.
If there any way to make Revit do this?
Thank you for any help as always!
Fri, Jun 13, 2008 at 2:47:55 PM | Viewing sloping beams
mhans
3 Stars: 10 Votes
If it's a 3D element and a section cut passes through it, revit will show a section cut. I suggest, you modify the section cut on plan to show staggered section line (use split segment at the option bar). See image. It might help.
Motto: "No Post left behind"
connecting steel beams
Thu, Apr 8, 2010 at 9:33:24 AM
3D Transparent Viewing
Mon, Jun 9, 2008 at 5:45:00 PM
Joining beams to walls and floors
Thu, Jan 15, 2009 at 9:00:36 AM
Sloping Columns
Tue, Jan 22, 2008 at 1:45:44 PM
Attching objects to a toposurface
Fri, Oct 24, 2008 at 6:48:35 AM
Page generation time: 0.5654
