Forums >> Revit Structure >> Technical Support >> Framing elevation to section
Fri, Jun 13, 2008 at 8:06:11 AM | Framing elevation to section
clarkrob
In Revit Structure 2008, is it possible to convert a framing elevation into a section? So that it keeps it annotations and dimensions and thus forth?
Thank you for any help
Fri, Jun 13, 2008 at 2:54:41 PM | Framing elevation to section
mhans
3 Stars: 10 Votes
Create a section cut as if it is cutting anything and looking to the direction of your elevation view. From your elevation view, copy to clipboard all annotaions, dimensions, detail lines, etc. and use Paste aligned, same place.
Motto: "No Post left behind"
framing elevation tag
Fri, Jul 18, 2008 at 3:59:53 PM
Callout on a framing elevation
Mon, Oct 5, 2009 at 8:29:41 PM
structural framing family cut pattern interacting with wall in section 2017
Wed, Sep 5, 2018 at 12:52:56 AM
DIFFERENT LINE THICKNESSES FOR STRUCTURAL FRAMING ELEMENTS IN SECTION
Tue, Sep 28, 2010 at 7:16:14 AM
Section cut tag not showing on foundation or roof framing plan..
Sat, Nov 1, 2008 at 7:54:03 AM
Page generation time: 0.4382
