Forums >> Revit Building >> Technical Support >> duplicate at a different level
Thu, Jun 12, 2008 at 7:52:58 AM | duplicate at a different level
emosms
Hallo,
does anyone tried to copy a repetative construct to multiple levels?
for example i have a grid of beams on a level , and i am going to have it at 8 levels, i really dont want to draw manually the same on each level.The beams grid is not a beam sysem, cause it does not generate what i need.
I tried once to group some various ellements, then copy the group, paste it into itself (at the same origin in section/elevation view), and still with  the duplicate selected after the duplication, i give it another level from the properties.But this is weird and awkward.
Isn't there something like the grid lines "propagate extents"?
Thu, Jun 12, 2008 at 8:16:35 AM | duplicate at a different level
Select items in plan, copy to clipboard then edit / paste aligned / select levels by name & pick the levels you want to paste to.  You can select more than one leval at a time.
Thu, Jun 12, 2008 at 11:48:57 AM | duplicate at a different level
emosms
well, this is great
thank you
Unable to duplicate a view
Tue, Sep 13, 2011 at 6:44:21 PM
create new "level" or duplicate w/ detailing?
Tue, Jan 17, 2006 at 4:06:24 PM
Unable to Duplicate Schedule
Wed, Sep 12, 2012 at 3:43:41 PM
Duplicate view
Wed, Jul 15, 2015 at 1:50:18 PM
phantom level showing up on elevation
Mon, Jul 14, 2008 at 4:43:22 PM
Page generation time: 0.4180
