26 Users Online (24 Members):
Forums >> Revit Structure >> Technical Support >> HOW TO..Create a pile schedule in revit and give co-ordinates?
I have about 1,118 piles which i have to get the co-ordinates for and put in a schedule. I first need to number all my piles and then extract the coorinate information from them - How the hell do you do this in Revit!!!!! thanks in advance people!!
Your building needs positiong correctly firstly and then set up a shared parameter to get the EN off onto the schedule. To number your piles, firstly get the piles on the drawing and then pull off the schedule which includes the mark. Then, simply go down and number then in the mark and it numbers the piles for you. I have been told there is a 3rd party application on its way to automatically do this and also get the pile cut off levels! Hope this helps?
Thanks for that. That 3rd party application would be really handy!!
Tell me about it! I am having a similar problem
Check out the extensions availble with your subscription . I thik this is the one you are looking for: http://www.extensions4revit.com/n/e4r/856/60
Creating a Pile Schedule |
Mon, May 23, 2011 at 10:37:27 AM
Pile cut-off Level, Adding Parameter to Pile Family ?????? |
Tue, Oct 16, 2012 at 2:39:10 PM
Elevation parameter in pile-schedule |
Tue, Feb 19, 2013 at 4:28:38 AM
Pile Schedule / Record |
Mon, Apr 28, 2008 at 1:48:47 PM
Pile Caps - Schedules Vs. Takeoffs |
Mon, Nov 5, 2012 at 10:42:33 AM
