Forums >> Revit Building >> Technical Support >> Shadows on plan view cast from cut plane
Wed, Jun 11, 2008 at 9:23:11 PM | Shadows on plan view cast from cut plane
awat
Hi,
I am trying to cast shadows in a plan view that is of the lowest level of a high rise building - because of this, when I turn on shadows the entire plan is in shadow.  I would like to cast a small shadow from each wall/ramp for a presentation effect/depth and would like to know if I can do it in Revit instead of bringing it into photoshop.
 Any suggestions would be great.  Cheers.
Thu, Jun 12, 2008 at 1:43:32 AM | Shadows on plan view cast from cut plane
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Shadows in a plan view are cast from the cut plane level.  Is this what you are asking or do you want the reverse, that is the shadow of the entire building?
Regards,
Chris.
Wed, Sep 24, 2008 at 9:24:32 AM | Shadows on plan view cast from cut plane
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Is there a way to have it cast shadows fromt he entire building?
 Thanks,
cad.web.print
Shadows & Cut Planes
Wed, Jun 15, 2011 at 12:24:13 AM
Shadows on floor plans
Sat, May 18, 2013 at 7:41:40 PM
Internal Shadows in Plan view
Thu, Sep 14, 2006 at 1:17:38 AM
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:44 PM
convert generic wall and roof to cast colored shadows
Sat, Oct 20, 2012 at 6:05:40 AM
Page generation time: 2.1015
