Forums >> Revit Building >> Technical Support >> Autocad 3d solids dissapear once I 'full explode' the model in Revit
Wed, Jun 11, 2008 at 7:56:22 PM | Autocad 3d solids dissapear once I 'full explode' the model in Revit
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
What I am trying to accomplish is to convert a heap of Autocad 3d models of fixtures into Revit.
I import the 3d model dwg into a Family file.  I select 'full explode' as I hope to re-use the existing geometry to create my family.  Once the 'full explode' is activated I get an error 'Import contained 3D data or points which can't be exploded. Only 2D data was exploded.'
Is there anyway around this?????
Wed, Jun 11, 2008 at 8:10:24 PM | Autocad 3d solids dissapear once I 'full explode' the model in Revit
mhans
3 Stars: 10 Votes
I think not. 3dmesh and 3dsolids from autocad (and even the one's that were done with sketchup) should not be exploded once  import them to revit. You can only Move-Copy-Rotate-Array-Mirror-Scale.
Motto: "No Post left behind"
Wed, Jun 11, 2008 at 8:27:52 PM | Autocad 3d solids dissapear once I 'full explode' the model in Revit
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
So, in your opinion do you suggest tracing these models in Revit???? then dumping the Autocad data
Wed, Jun 11, 2008 at 8:59:16 PM | Autocad 3d solids dissapear once I 'full explode' the model in Revit
mhans
3 Stars: 10 Votes
If it's for schematics you can use them as they are, but not for Design Devt or Const Doc. because of their limitations. Tracing over them will help because you can pick corners and sides. I normally import 3d models (from acad or skp) as standalone objects or as backgrounds.
Wed, Jun 11, 2008 at 9:07:12 PM | Autocad 3d solids dissapear once I 'full explode' the model in Revit
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Cheers
Im starting to trace. Not as much work as I thought as there are alot of common parts/peices (my guts went one way and my legs went the other Smile ) Im gonna creat a heap of nesteed families. Giddy up.
They are for  Design Devt or Const Documents.
Can't explode in 2010
Fri, Apr 17, 2009 at 4:13:21 PM
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Geodesic Dome
Wed, Oct 19, 2005 at 11:27:33 PM
Disillusionedwith Revit
Tue, Aug 22, 2006 at 6:57:21 PM
Page generation time: 2.1862
