Forums >> Revit Building >> Technical Support >> Revit 2009 shortcut for panning not working
Wed, Jun 11, 2008 at 3:12:04 PM | Revit 2009 shortcut for panning not working
sattoji
I just installed Revit 2009 and have transferred my old custom keyboard shortcuts to the new shortcut file. They all seem to work so far except for one I had in Revit 2008, where I was able to access "View - Dynamically Modify VIew" with the shortcut "ZZ" (btw no reference to the french slang here!). When I try to use this shortcut in R2009 to access the command "View-Zoom-Pan Active View", it doesn't work... does this command even exist? Or have they eliminated any such command line with the introduction of the navigation wheels?
By the way, I can't use my middle mouse button or scroll wheel button for panning. I am running a MacBook Pro with Parallels and Windows XP (Home), and the logitech software greys out the options for scroll button with Parallels... So right now my only recourse to pan is to use the navigation wheel which so far I DO NOT like much.
Thanks for any help,
Satto
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6
Wed, Jun 11, 2008 at 8:53:43 PM | Revit 2009 shortcut for panning not working
mhans
3 Stars: 10 Votes
Does it happens only with your recent installation of Revit 2009 or with RAC2008 also? Download latest parallels version and reload again, it might help
Motto: "No Post left behind"
Wed, Jun 11, 2008 at 11:31:50 PM | Revit 2009 shortcut for panning not working
sattoji
I just upgraded to Parallels 3.0 and Revit 2009 at the same time. So no luck there. I had the "ZZ" shortcut working fine in RAC2008, but the command line was different - for Dynamically Modify View instead of Pan ACtive View.
Thu, Jun 12, 2008 at 1:38:50 AM | Revit 2009 shortcut for panning not working
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
ZZ is a default command for zoom window.  Ensure you don't have a duplicate setup.
Regards,
Chris.
Thu, Jun 12, 2008 at 2:53:05 AM | Revit 2009 shortcut for panning not working
sattoji
Thanks Chris,
I eliminated "zz" for the zoom window command in the shortcut text file before creating one for the pan command. Is there some other ghost or system command file that would override these shortcuts? I've tried other letter combinations but nothing seems to work for that command.
Also, I've added "VA" for Activate View and "PA" for Paste Current View, and they are not working either.
I'm stumped.
Mon, Jun 16, 2008 at 10:46:24 PM | Revit 2009 shortcut for panning not working
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When you type the command look at the bottom status bar, it lists the commands associated to that key combination.  If there are duplicates you can use your arrow keys to switch between them and then hit enter to commit to one.  If it isn't showing in your status bar there is something wrong with the shortcuts file...
HTH.
Regards,
Chris.
Tue, Jun 17, 2008 at 1:31:20 AM | Revit 2009 shortcut for panning not working
Elmo
3.5 Stars: 4 Votes
The new default for this command seems to be F8 from what I can see in my file. Try removing that and inputting your default and see if it works.
Edited on: Tue, Jun 17, 2008 at 1:34:00 AM
Doesn't move while panning?
Sat, Apr 20, 2013 at 8:50:42 PM
Looking for quick Key shortcut
Thu, Jul 2, 2009 at 10:22:19 AM
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
working in Revit 2009
Thu, May 29, 2008 at 3:58:18 PM
Keyboard Shortcut file location for Vista
Mon, Oct 13, 2008 at 1:35:19 PM
Page generation time: 3.7102
