25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> How do I conver my Family Library from revit 2008 to 2009?
As an office we have our standars library full of the cabinet types we use etc. There are hundreds of families, is there a utility or something that I can use to just convert a whole folder of families from revit 2008 to 2009? Opening them individually and then resaving them just isn't going to do it. Any sugestions?
so far, I haven't heard of such Family manager. Tell me it you find one. I suggest you just have to update your family as you would need them and you know that once they are upgraded, there's no turning back.save a separate copies for your original 2008 versions.
i think in the past they have provided a batch utility on the cd for converting purposes. i'm not 100% sure though. HTH
From the AUGI site: There's a Batch file called Upgrade_RFA.bat that's either on your Install disk or in the "Download" folder wherever you did your initial install. I found mine in C:\Program Files\Revit Architecture 2009\Download\Utilities\Common\ContentBatchUtility Don't jsut run that file, though. There's also a .txt file in the same folder that explains how the whole upgrade process.
Thanks for the info. I might use them someday.
Revit Online Content Distributor...2009? |
Mon, May 12, 2008 at 4:17:07 PM
using revit 2008 project in revit 2009...plz help |
Tue, May 27, 2008 at 8:44:38 AM
Open 2009 Files in 2008 |
Mon, Aug 4, 2008 at 1:10:04 PM
Revit 2009 file size DOUBLE 2008!?!? |
Thu, Jul 17, 2008 at 11:34:24 PM
Revit 2009 Web Library |
Wed, May 21, 2008 at 4:13:53 PM
