Forums >> Revit Building >> Technical Support >> rpc in 2009
Wed, Jun 11, 2008 at 9:55:57 AM | rpc in 2009
BRIANHADLEY
I have placed some rpcs for plants in my model but the image doesn't show in the views only in the rendering.  Is there a way to move or delete the rpcs.  I have placed them in incorrect locations.
Wed, Jun 11, 2008 at 12:12:13 PM | rpc in 2009
KingRevit
4 Stars: 12 Votes
are the the rpc from the standard liabary, because if the are the should show up, check your visibility settings.
Wed, Jun 11, 2008 at 2:40:41 PM | rpc in 2009
BRIANHADLEY
I got them from ArchRender.  In the family editor I can see the different views but when I bring them into my project they are not visible.
Wed, Jun 11, 2008 at 8:17:13 PM | rpc in 2009
mhans
3 Stars: 10 Votes
you should recreate your rcp's. Chances are you only got the bitmap part of it. Put a model symbol as a placeholder.
Motto: "No Post left behind"
Fri, Jun 13, 2008 at 3:14:49 AM | rpc in 2009
Elmo
3.5 Stars: 4 Votes
I've found that if you have brought in an rpc content into 2009 it does not automatically show. I have found that if you open the family and rebring it back into the project it tends to fix or it bring the defualts from the metric library.
Another thing that I have found is if you put new rpc people or cars in to the rpc librart it does not work or pick up the files. I have found that if you rename the rpc to archivision_ at the file name structure and restart revit it will then pick up the files in your rpc locations. Funny but true.
RPC and revit 2009
Mon, Jun 1, 2009 at 11:55:15 PM
2009 RPC files
Thu, Sep 9, 2010 at 2:47:12 PM
Revit 2009 - RPC's
Thu, Sep 9, 2010 at 3:16:34 PM
cannot see Decal and Rpc elements in new project 2009
Sun, Nov 23, 2008 at 5:17:13 AM
Uploading existing RPC content into 2009
Fri, Nov 14, 2008 at 2:37:54 AM
Page generation time: 5.4666
