Forums >> Revit Building >> Technical Support >> Door Schedules: Adding a Header Cell
Tue, Jun 10, 2008 at 7:04:22 PM | Door Schedules: Adding a Header Cell
raredmon
How do I group headers in a door schedule under another header?  (Ex. I want to have "Finish", "Type", & "Material"  all fall under the header: "DOOR", but to remain headers themselves.)
Revit 2008
Tue, Jun 10, 2008 at 8:08:22 PM | Door Schedules: Adding a Header Cell
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your schedule, select the headers you wish to group.  Now look at the status bar, there is an option for "Group".
HTH.
Regards,
Chris.
Wed, Jun 11, 2008 at 10:37:34 AM | Door Schedules: Adding a Header Cell
raredmon
Yeah, I got it...Thanks! I didn't realize you could simply click and drag to select multiple headings.
Thu, Oct 24, 2013 at 8:31:00 PM | Door Schedules: Adding a Header Cell
danimakes
Hi Guys! I realize this thread is ancient but I'm having issues with grouped cell headers and I cannot figure it out for the life of me. I joined several headers in my schedule and now they have split again. I can no longer join them, and I can't delete them.
Please let me know if this is a bug or if there's any solution.
Thanks!
Thu, Oct 24, 2013 at 8:35:21 PM | Door Schedules: Adding a Header Cell
danimakes
Thanks!
Thu, Oct 24, 2013 at 9:39:16 PM | Door Schedules: Adding a Header Cell
CDWdavid
5 Stars: 5 Votes
Please see attached pdf file. I'm working on Revit 2013.
Try followings:
1. Go to Schedule View.
2. Select the cells you want to have the group header, my case was select "HEAD", "JAMB" and "SILL", then right click, in pop-up window select "Group Headers".
3. A new empty grouped cell will be shown on top of those three cells.
4. You can type any word in there, I typed "DETAILS".
5. Then turn to sheet view, my case is A-101, you can drag them to set up the height and width as you like.
Edited on: Thu, Oct 24, 2013 at 9:47:25 PM
Thu, May 8, 2014 at 11:42:20 AM | Door Schedules: Adding a Header Cell
olivermason
That seems to be a promising idea, what are guides and materials aside from the door? And will it work for the custom made ordinary door? Do you have a link for those resources you have?
Thu, May 8, 2014 at 10:39:19 PM | Door Schedules: Adding a Header Cell
CDWdavid
5 Stars: 5 Votes
Here is the link to my post.
http://www.revitcity.com/downloads.php?action=view&object_id=11969
You may download it and try. Hope it helps.
Door Schedules - Changing Cell Font to Mark Further Review
Tue, May 22, 2018 at 8:52:57 AM
Schedules - Cell Height Adjustments
Wed, Mar 21, 2018 at 12:40:09 PM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:23 AM
Door headers
Mon, Sep 22, 2008 at 3:13:25 PM
Necessary to reinvent the wheel with door schedules?
Wed, Feb 10, 2016 at 9:48:56 AM
Page generation time: 1.7077
