Forums >> Revit Building >> Technical Support >> rom finish tag
Wed, Apr 6, 2005 at 9:27:41 AM | rom finish tag
Bimman
Bimman Avatar
1 Stars: 2 Votes
i am looking for a room finish tag that would go in each room and pull its info from the the finish schedule. so the info could be in each room rather than having to flip back and forth to the finish schedule. this is a new area for me in revit i have not used finish schedules until now. thanks pete
PWD
Wed, Apr 6, 2005 at 11:02:13 AM | RE: rom finish tag
TomDorner
4.5 Stars: 25 Votes
Pete, Take a look at the attached tag. We only display the wall finish and floor finish, but you could modify to display anything you want. This tag simply uses the standard Revit "labels" which is Revit speak for the database term "field". Labels in Revit simply display the underlying data of an object. In this case the object is the room (not the room tag). HTH Tom
Mon, Apr 23, 2007 at 2:38:01 PM | rom finish tag
daryl
Tom,
I downloaded your room tag with finishes. I created a small four room bldg with a floor, used the room tool to create four rooms, and then substituted your tag for the default room tag. The tag picked up the room numbers, but not the wall and floor finishes. Any suggestions as to what I did wrong?
 Thanks
Daryl Stockton
Mon, Apr 23, 2007 at 2:41:05 PM | rom finish tag
daryl
We are using Revit 9.1, the second build I think.
Mon, Apr 23, 2007 at 5:50:40 PM | rom finish tag
TomDorner
4.5 Stars: 25 Votes
Boy this thread and the tag I supplied are two years old!
The tag should still work in 9.1  It simply reads the properties in the room object for wall and floor finishes.  Go to a room object and fill in those finish fields or create a room schedule and fill them in there.
Tom
Mon, Apr 23, 2007 at 5:58:34 PM | rom finish tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Might just clarify that these tags do not read the actual material used on the walls/ceilings/floors.  They have to be entered in manually into the room parameters.
Regards,
Chris.
Mon, Apr 23, 2007 at 7:55:22 PM | rom finish tag
daryl
Thanks guys. I should have realized the tag doesn't pick up the materials. I will get the schedules made.
Adding Room Tag Parameters
Tue, Oct 24, 2006 at 10:29:46 AM
Finish Schedules, Finish Elevations and Plans
Thu, Dec 16, 2010 at 2:52:44 PM
String Values in Formulas
Tue, Jul 5, 2011 at 12:22:03 PM
Hospital Bed (Hill-Rom) Maybe??
Tue, Sep 18, 2012 at 5:29:09 PM
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:18 PM
Page generation time: 0.7285
