31 Users Online (29 Members):
Forums >> Revit Building >> Tips & Tricks >> Cut-Away View
I am working in RAC 2009, and working on a floor framing plan for a residential project, and would like to be able to re-produce this cut away view sh2owing the different materials in the framing, like in the CAD example below. has anyone done this, or does anyone know if this is possible in Revit. see the PDF example below. Thanks.
Check out your help under "orient". Also check out the forum archives using the same term. That is where I found this thread. http://www.revitcity.com/forums.php?action=viewthread&thread_id=374
acutally, i got the answer from the Augi forum. since it is not in 3D, just in plan, I could do a filled region over top of the structural joists and show it that way.
window does not get cut in plan view. |
Tue, Jul 12, 2011 at 10:37:20 AM
Revit Architecture 2012 - Section shows view from behind cut line |
Thu, Jan 10, 2013 at 12:38:20 PM
Model view section cut refer to a drafting view |
Wed, Nov 13, 2019 at 5:44:08 AM
Plan view view range |
Fri, Nov 2, 2018 at 6:59:27 PM
Cut Geometry shows in 3D and Plan but not in Section? |
Fri, Nov 30, 2012 at 1:44:30 PM
