7 Users Online (6 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Another New Guy with a question
Tue, Jun 10, 2008 at 7:47:17 AM | Another New Guy with a question
JGATOR
I work at a small (7 project managers) commercial construction firm. I do all the in-house generated drafting. I started using Revit a few months ago and I am using 2009. I can do about 95% of what I need to generate in Revit.
I am having a problem with a hatch (for lack of a better word) that I downloaded from here. I am trying to get a cultured stone look and downloaded a .pat file. How do I get that pattern into the drawing? Did I get the correct file format to insert into the Revit file?
Thanks in advance.
Tue, Jun 10, 2008 at 8:06:12 AM | Another New Guy with a question
We could give you an easy answer but I will give you a better one that will help you a lot more.  There have many many subjects covered here in the past and all are in the forum archives.   If you learn to look there and in your REVIT help, you will find a lot of your beginner questions answered.  Try searching in the forum for "hatch" or "patteren" and you will find your answer.  Using "pattern" in your help search will also give you your answers.
Wed, Jun 11, 2008 at 11:26:38 AM | Another New Guy with a question
JGATOR
Found it. Thanks. I did notice one difference in the instructions I found and it may be because I am using 2009 and those instructions may come from an earlier version. I had to go to: Settings-Fill Patterns-toggle "model" button-New-toggle "custom" button (this causes the "import" button to come up)-import
Toggling the "custom" button was an additional step I did not see mentioned in the posts I looked through.
New guy with question
Fri, Dec 28, 2007 at 9:38:28 AM
New guy - initially exploring collaborating remotely with large Revit projects
Wed, Mar 5, 2008 at 1:57:05 PM
download question
Wed, Jun 21, 2006 at 8:09:34 PM
Just trying to keep my job
Tue, Jan 26, 2010 at 11:51:47 AM
newb, FNG, howdy
Thu, May 30, 2013 at 9:34:55 AM
Page generation time: 0.6643
