16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Exporting with shared coordinates
5 Posts No Rating |
Hi, does anyone know why when exporting plan views to dwg (with shared coordinates) only drafting lines and annotations appear in the dwg file? Is there a setting to turn on model lines? I've exported 3D views from rvt to dwg from this file and they appear in the correct position with all model lines - its just not working for 2D plans.
Exporting with shared co-ordinates doesn't work from sheets. Are you doing this? HTH.
Regards,
Chris.
5 Posts No Rating |
No, I am exporting from Plan Views. The coordinates are correct for the annotations that export, just no model lines are visable so its almost a blank dwg.
Are you saying there are no walls/doors/windows etc on the view your are trying to export? Is it just detail and model lines? Try turning on the crop region also and try exporting, as I have experienced that effecting the correct export of shared coordinates.
Regards,
Chris.
5 Posts No Rating |
Thanks Chris - Yes I meant that I couldn't see anything I'd modelled (walls, families, floors etc), only annotations. I've tried with the crop region both on and off, possibly just a glitch with the file? I'll keep trying, but thanks for your advice!
Exporting sheets to dwg with shared coordinates |
Tue, May 6, 2008 at 9:50:37 PM
Exporting to CAD by shared coordinates |
Mon, Dec 1, 2014 at 7:57:28 AM
Shared Coordinates while linking Dwg into Rvt |
Thu, Jun 5, 2014 at 12:06:32 PM
Shared Coordinates |
Sat, Mar 6, 2010 at 10:06:14 PM
Toposurface - CSV import to shared coordinates |
Thu, Aug 22, 2013 at 2:59:54 PM
