Forums >> Community >> Newbies >> Trouble with Roof
Mon, Jun 9, 2008 at 4:34:20 PM | Trouble with Roof
what
Hello everyone, I have been having trouble with the roof for a building.  When I set up a general roof with the quick button, it creates a 4 panelled roof where the roof peak is only about half the length of the building (the roof raises to the peak from all 4 sides).  What I need to do is have just a 2 panel roof where the peak of the roof goes the length of the building (the roof raises only from the two lengthwise sides).  I am not an Architect so I apologize if I don't know some of the technical names for stuff on here.  Any help you could give me would be great.  Thank you.
Tue, Jun 10, 2008 at 6:32:30 AM | Trouble with Roof
IDN101
2.5 Stars: 3 Votes
You need to edit the roof.
When in Sketch Mode- turn OFF "Toggle Roof Sloping" for the two side that you do not want hipped. Then click "Finsih Sketch". Job Done.
 Also, remember to then use the "Attach" command to join the end walls to the underside of the roof.
 Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Tue, Jun 10, 2008 at 8:33:43 AM | Trouble with Roof
what
Thank you very much.  Learning new things every day...
Roof Join / Entension Trouble
Thu, Feb 11, 2016 at 9:52:09 AM
Roof Extrusion Trouble
Tue, Mar 5, 2013 at 12:43:01 PM
Dome roof
Mon, Jan 17, 2011 at 7:52:22 AM
13
Wall, window, and roof. Trouble getting the window to not go through roof
Tue, Mar 15, 2011 at 1:40:00 PM
Trouble with Roof
Sat, Dec 14, 2013 at 6:15:19 PM
Page generation time: 0.4828
