Forums >> Revit Building >> Technical Support >> Displaying membrane layers as dashed lines in detail view
Mon, Jun 9, 2008 at 2:17:29 PM | Displaying membrane layers as dashed lines in detail view
Asidie
Hi all,
 I have to know:
Is it possible to display the membrane layer (in wall structure) as a dashed lines in detail section view and tag it as a material?
Thanks to all
Math
Mon, Jun 9, 2008 at 3:43:11 PM | Displaying membrane layers as dashed lines in detail view
mhans
3 Stars: 10 Votes
No, Membrane layer won't allow you to give it a thickness & hatch it. But you can oversize your finish and draw over it a hidden line (in detail/drafting view) that you want. Or for drafting purposes, you can assign a Finish as a function instead of using the Membrane layer. Then you will be able to use a cut pattern and if you have ACAD.pat, acad_isow100 will be fine for a pattern, just adjust the scale to suit. If your cut detail is not that many, just do a hidden line on your drafting view, i suggest.
Motto: "No Post left behind"
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 5:11:55 PM
Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM
detail lines WITHIN wall types
Wed, Jul 11, 2007 at 6:26:11 PM
damp proof membrane in section
Fri, Mar 18, 2011 at 8:32:16 AM
Page generation time: 1.3829
