Forums >> Community >> Newbies >> Drawing conventions
Mon, Jun 9, 2008 at 10:50:13 AM | Drawing conventions
horicolonoma
Hello all, I am a Noob with Revit and the community...
 First of all I have Revit 2009. I found out that the drawing conventions are very American and not European...
As I am trained in European conventions, I would like to use them...some examples:
    - when I have a shaft like an elevator or service core, we add a cross to show that the space is running vertical through the building
    - when there is a structure cantilevering on the other floor on top we use a hashed line to show it is there...
This is all the problem in plan view
Thanks for your help
Mon, Jun 9, 2008 at 11:02:37 AM | Drawing conventions
4 Stars: 205 Votes
Hi and welcome in Revit World, i also use European conventions but do you made a question? what's the problem with the two examples you post? You can drew like do you want, you can use and abuse from Revit capacities...so?
Mon, Jun 9, 2008 at 11:10:28 AM | Drawing conventions
horicolonoma
hmmm thanks for the fast reply
I learn that Revit makes a lot of automatic decisions, so I would like to use them...
     Q1: How can I show the lines in plan that show the lines above the head (which are invisible, dashed)
     q2: how can I show in plan that a shaft or a service core has a cross?
Thank you
Mon, Jun 9, 2008 at 11:26:42 AM | Drawing conventions
4 Stars: 205 Votes
Hi again, in plan go VP and you can change the elevation of "cut plane" the "Top and Bottom level", but you also have in left pop menu a "Drafting" witch you can draw and create hatch and different kind of lines, if you have difficultes you also have the HELP menu....
parameter naming conventions
Thu, Apr 2, 2015 at 8:44:13 PM
Naming Conventions
Tue, Jun 7, 2011 at 5:45:11 AM
Revit 2009 Naming Conventions for Detail Titles
Fri, Aug 26, 2011 at 11:25:41 AM
Revit 2009 Schedules
Mon, Jul 25, 2011 at 10:22:50 AM
Family Naming Guideline
Thu, Dec 11, 2008 at 5:42:49 AM
Page generation time: 0.1457
