Forums >> Revit Building >> Technical Support >> How to Unfold Window???
Mon, Jun 9, 2008 at 9:08:08 AM | How to Unfold Window???
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
I have a corner window(or Curved Wall) in my project, but I want to represent it as unfolded in the Schedules (or Legends).
Thanks
Pavan Reddy
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Wed, Jan 14, 2009 at 9:02:09 PM | How to Unfold Window???
elduderino1234
Did you ever get an answer to this? I am currently trying to do the exact same thing
Thu, Jan 15, 2009 at 1:46:33 AM | How to Unfold Window???
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
No, I didn't get. You can palce 2 elevations on either sides and place 2 elvations side by side or draft it.
Pavan Reddy
Revit Manager
Thu, Jan 15, 2009 at 1:49:18 AM | How to Unfold Window???
mgr2820
2 Stars: 2 Votes
If its a curved wall you must draft it as a drafting view, then place an elevation and link to it.
If its a series if angled walls, you can splice mulitple elevation views together, then hide all but one elevation call out.
Thu, Jan 15, 2009 at 12:04:46 PM | How to Unfold Window???
elduderino1234
The window I am trying to show is multi angled (like the letter Z, except all angles are 90 degrees). However, in the window legend, I am only able to show front and rear elevations. Is there a way to add a side elevation as well? Thanks
How do I unfold and elevation with accuracy?
Thu, Sep 4, 2008 at 6:52:42 PM
Using Revit to Detail Complex Curved Geometry (Rhino/Inventor Unfold Command)
Wed, Apr 17, 2013 at 9:16:36 AM
Can Revit Unfold 3d objects for 2D CNC processing?
Fri, Oct 19, 2012 at 10:41:12 AM
Window sashes with different window numbers in the window schedule
Tue, Mar 19, 2024 at 11:49:53 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
Page generation time: 0.9214
