Forums >> Revit Building >> Technical Support >> Images uderlayed beneath 3-d views (Revit 2008)
Mon, Jun 9, 2008 at 7:41:50 AM | Images uderlayed beneath 3-d views (Revit 2008)
benlink
I'm in need of a means to get an aerial city view underlayed beneath my 3-d views.  Any file type would be fine, it doesn't matter.  Though, in 3-d views, under File >Import> Image..."Image" is greyed out.  Is there a work around, or some other means to do this?
thanks,
Ben
Mon, Jun 9, 2008 at 10:08:17 AM | Images uderlayed beneath 3-d views (Revit 2008)
4 Stars: 205 Votes
Hy, you can't import an image in 3d-view but you can create a PAD in SITE view and assign the .JPG like a material, so when you render the image you want appear in scene... i think that's what you want... if not shoot....
Tue, Jun 10, 2008 at 1:37:16 PM | Images uderlayed beneath 3-d views (Revit 2008)
benlink
Well, I tried this, and couldn't get the city blocks accurate.  Had to rely on the trusty Photoshop.
Thanks anyway.
imported revit structure and no visibility beneath
Tue, Jan 27, 2009 at 2:29:28 PM
Camera views export blank images
Mon, Dec 9, 2013 at 2:13:16 PM
How to remove the layer beneath on planview?
Wed, Dec 4, 2013 at 2:47:04 PM
2008 - kEYNOTING DRAFTING VIEWS
Mon, May 12, 2008 at 7:35:00 AM
Linking raster images into revit 2008... Do Not Update?
Fri, Apr 4, 2008 at 8:11:43 AM
Page generation time: 2.8944
