Forums >> Revit Structure >> Technical Support >> Linking Callouts Between Revit Models
Mon, Jun 9, 2008 at 6:32:45 AM | Linking Callouts Between Revit Models
MartinGT
1 Stars: 1 Votes
Hi I have two buildings with the same masonry details.  I have detailed several callouts in one model and instead of doing it again I would like to link the details somewhow.
Is this possible?
Mon, Jun 9, 2008 at 4:04:57 PM | Linking Callouts Between Revit Models
mhans
3 Stars: 10 Votes
I had the same scene. I can't import deteail view from the other model file. I tried insert file and found out it only works with drafting view and drafting sheets. I ended up combining the two models in one, so just I could have the same callouts and refering details common to both bldgs. Hope to see more light in linking. It is so limited to just seeing the model without able to anything about it, except view and unview.
Motto: "No Post left behind"
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Referencing Callouts in linked models
Wed, Jul 3, 2013 at 12:02:20 PM
Linking the Autodesk Advanced Models Together
Mon, May 19, 2014 at 2:02:04 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Page generation time: 1.8950
