Forums >> Revit Building >> Technical Support >> EDITING TEXT LEADER ARROWHEADS AND LINES
Sat, Jun 7, 2008 at 7:45:08 AM | EDITING TEXT LEADER ARROWHEADS AND LINES
grrant
Hello fellow revit users, This question relates to adding text with a leader and arrow head when documenting drawings. I would like to know if it is possible to first of all edit or create my own arrow leader heads. Instead of the standard ones available I would like a 1.5mm black dot (However a 3mm dot is available in the standard selection). Instead of the black solid leader line, I would like to create a dotted freehand leader. Can anybody help me ? is this possible and how would I go about doing it ? I am using revit 2009, any help on this topic would be greatly appreciated.
Tue, Jun 10, 2008 at 4:52:44 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
mhans
3 Stars: 10 Votes
Did you say text and not tags? Leaders are system family so you can't add a new type to it. But you can modify the ones that are already built-in, like their arrow style, fill, width angle and sizes. Those are the very basics we use. You can find them under Settings, Annotations, Arrowheads. You can't assign another linetype for the leader.
Motto: "No Post left behind"
Wed, Jun 11, 2008 at 2:10:12 AM | EDITING TEXT LEADER ARROWHEADS AND LINES
grrant
thankyou for the help, I will edit the arrowhead however will have to settle with the solid black line as the standard leader
Thu, Aug 14, 2008 at 1:33:30 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Is it possible  to draw leaders from the end of the text in Revit? It just looks a little bit cleaner...
Thanks in advance!
Tim McDougald
CHILDREY ROBINSON ASSOCIATES
1212 Kenilworth Avenue
Charlotte, NC  28204
Thu, Aug 14, 2008 at 2:09:39 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
Belinski
4 Stars: 5 Votes
The only way this is possible is if the text is a single character, like a single number of letter.
Then you can just move the box right to the edge of the character and it looks like the leader is coming straight from it.
Thu, Aug 14, 2008 at 2:16:30 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
cadpro78
cadpro78 Avatar
3 Stars: 2 Votes
Well gosh... I guess I will have to live without it being neat sometimes... :-)
I'll see if that way every comes in handle... it probably will. I guess I'm just too use to AutoCAD's ways..
Thanks anyway.
Tim McDougald
Charlotte, NC  28204
Thu, Aug 14, 2008 at 2:43:27 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
Belinski
4 Stars: 5 Votes
Ya AurtoCad is alot less complex than Revit, which makes it easier to change small things like these spacings..
Thu, Aug 14, 2008 at 3:14:57 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
mhans
3 Stars: 10 Votes
In most cases use tags rather than text. As a workaround, create a 'Text Tag' (edit Material tag family and saveas and chanage the label to Comments instead of description) and use it for tagging items. It has some restrictions, like you cannot tag the same object with a different text similar to not tagging the same material with different type.
Thu, Aug 14, 2008 at 3:21:20 PM | EDITING TEXT LEADER ARROWHEADS AND LINES
Belinski
4 Stars: 5 Votes
I didnt even think of that, that is a good work around
distance between text and leader lines able to be changed?
Fri, Sep 12, 2008 at 10:20:21 AM
leader arrowheads
Fri, Jul 21, 2006 at 5:30:20 PM
leader lines
Mon, Jan 19, 2009 at 2:39:06 PM
Arrowhead start position with text box
Mon, Aug 3, 2009 at 9:19:59 PM
drawing a leader/arrowhead without text?
Mon, May 31, 2010 at 10:54:51 AM
Page generation time: 0.4884
