Forums >> Revit Building >> Technical Support >> stair stringer endings
Tue, Apr 5, 2005 at 6:00:24 PM | stair stringer endings
kkim
Does anyone know how to modify the stair properties so that the topmost stair tread depth is four inches wider ( than the normative tread depth of the flight) as it attaches to the edge of a floor slab? also, the (closed) stringers would have to be 'trimmed' to level off at two inches above the slab as they also attach to the floor slab. i can't figure out how to get the stringer to extend beyond the last tread. is any of this possible with the revitized stair or am i better off building the 'ends' of the staircases as separate elements that attach to the revit stair run? if you can help, eternally indebted.
Tue, Apr 5, 2005 at 6:35:08 PM | RE: stair stringer endings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Have you checked out the Autodesk Revit Stair White papers crib sheet...? (attached) This should help to explain what the different options do... As for having a different tread thickness for the top tread, this is currently not possible. You would need to model it as a separate element. HTH.
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Stair Stringer Question
Fri, Jul 28, 2017 at 4:01:08 PM
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Stair Stringer Cutting Stair Treads and Risers See Image
Thu, Jun 5, 2014 at 7:59:38 AM
Page generation time: 0.1314
